Certificates 56 years 3 months ago #5605
  • FOWLER's Avatar Topic Author
With 'World' champs looming, could we have, for clarification, the current Rules & Regs. on new sails & boyancy certs. Things are begining to move now, so we don't want to be caught out at the Eleventh Hour.
Rgds to All
Mark
Certificates 56 years 3 months ago #5607
  • Robert Thomson
  • Robert Thomson's Avatar
This is what the rules say.
On buoyancy
Part A 4.4 The certificate is valid for twelve months from the date of the
original buoyancy test or any subsequent buoyancy test provided it
is signed by the owner with the date of the last test and that this
signature is witnessed and endorsed by a person or persons in
each country designated by the respective national association.
Part B
4.2 TESTS
4.2.1 Buoyancy tests shall be undertaken by the owner who shall sign
and date the certificate and arrange for such signature to be
witnessed in accordance with rule 4.4 Part A.
4.2.2 The initial buoyancy test for boats with built-in buoyancy tanks shall
consist of either a dry pressure/vacuum test as defined in rule 4.2.3
or of the immersion of each buoyancy unit for at least 5 minutes
when all units shall be in sound condition. The initial buoyancy test
for boats without built-in buoyancy tanks shall consist of the
immersion of each buoyancy unit for at least 5 minutes when all
units shall be in sound condition. After an immersion test, each tank
shall contain not more than 1/2 litre of water.
4.2.3 At subsequent buoyancy tests, boats with hull shells and decks
constructed substantially of wood shall have, at yearly intervals,
their buoyancy apparatus checked by the owner (reference rule
4.4, Part A) who shall be satisfied that the buoyancy apparatus is in
a sound condition. Every third year or, if the owner is in any doubt
as to the adequacy of the buoyancy apparatus, a dry
pressure/vacuum test as defined in Rule 4.2.3 or an immersion test
as detailed in rule 4.2.1 shall be undertaken. Boats with hull shells
and/or decks constructed substantially of GRP. shall have a dry
pressure/vacuum test as defined in rule 4.2.3 or an immersion test
as detailed in rule 4.2.1 undertaken at yearly intervals.
SAILS
13.5 Additional Rules
13.5.1 Only sails endorsed in accordance with rule 13.5.2 shall be used.
13.5.2 Not more than one mainsail and not more than one headsail shall
be endorsed on the certificate when originally issued. Sails may be
added by endorsement as additions or replacements (but not both)
at the rate of one mainsail and one headsail (two headsails in the
UK) during each succeeding twelve month period commencing from
the date of issue of the original/initial measurement certificate. The
Association shall have the discretion to permit the endorsement of
further replacement sails in the event of loss or damage.
13.5.3 Not more than one mainsail and one headsail shall be carried on
board.
The rules can be downloaded from the technical section of the RYA's not very easy to navigate website. I couldn't get the link from this site to work, webmaster please note.
Hope this has helped, no doubt our chairman will be along shortly and may give a practical indication of what they will be checking. I would suggest that you get your buoyancy checked prior to the event. Not sure about who is actually allowed to sign as witness though, I'm sure a club Commodore used to be able to but Derek will be able to confirm approved persons
Robert(the currently boatless)
Certificates 56 years 3 months ago #5609
Okay
Got the bit about the bouyancy,if she floats We're ok
The sails on Against All Odds were insurance rite off in the floods last year, can I, funds permitting register a replacement suit & a new suit?
Original cert is July 1981
Certificates 56 years 3 months ago #5614
  • Robert Thomson
Replacement sails would be at the discretion of the association but you are certainly allowed one new set per year. Derek would be able to give you a more authoritive yeah or neah on this particular question.
Certificates 56 years 3 months ago #5615
This rule (sails replacement) is currently under review, however if you have had a new set of sails since july 2008 you will need to apply for a consession for the set lost in the floods and this I would imagine would be looked on favourably. If you have not had a new suit of sails since July 2008 then you obviuosly can do so. The bottom line (even if it is 12 months from last issue, or 12 months from original certificate you will only be allowed to have two mains and two jibs (which must be measured and on your certificate) prior to the start of next years championships.
Hope this helps.
www.rya.org.uk/KnowledgeBase/technical/Pages/technical.aspx
will get you to page containing class rules then choose "Albacore" option
Derek Gibbon
NAA Chairman
ps You should always have a spare set of sails at any champs as the committee can allow a swap if damage occurs.Derek Gibbon2008-10-18 15:28:25
Certificates 56 years 3 months ago #5617
Derek,
Thanks for making things clear.
Rgds
Mark...
Time to create page: 0.172 seconds
